ethernet port on 2511 ???
Answered Question
Sep 20th, 2007
The 2511 should have a ethernet interface, "interface Ethernet0
ip address x.x.x.x 255.255.255.0
no mop enabled"
But in the box, I only see Console and AUX port? No ethernet?
Any idea? How can I connect to this box through LAN ?
Correct Answer by Joe Clarke about 9 years 7 months ago
When you say, "in the box" I assume you mean you're looking at the physical chassis. The ethernet interface is there. It's an AUI interface (http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00801f5d86.shtml). You will need an ethernet trasceiver to convert the AUI interface to something more modern (i.e. RJ45).
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Thu, 09/20/2007 - 07:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
rico_hao40 Thu, 09/20/2007 - 12:06
Thanks.
Yes, I found the conveter AUI->RJ45. Now it works.
