Unable to route packets
jason.tan
I am facing a routing problem. Refer to the attached document for network topology.
On the C2811 router (IOS 12.4), I can ping to any local VLAN segments. But I can't ping to remote 10.10.31.x/24., other than .254 host. But on the C1841 router itself, I can ping to 10.10.31.x/24.
On the C1841 router (IOS 12.4), I can ping to 172.26.10.x xecept for .2, .1 and other VLANs. When I do a traceroute (eg to 172.26.10.2), the hop stop at 192.168.10.2.
Any1 know what's goes wrong?
spremkumar
Level 9
Level 9
hi
can you post the config of the routers ?
regds
****** C2811 ************
sh run
Building configuration...
Current configuration : 1976 bytes
version 12.4
service password-encryption
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret xxx
no aaa new-model
ip cef
ip domain name yourdomain.com
--More-- !
username vendor privilege 15 secret xxx
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$$FW_INSIDE$
ip address 192.168.10.2 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
description $FW_INSIDE$
ip address 172.x.x.254 255.255.255.0
duplex auto
speed auto
ip route 10.10.31.0 255.255.255.0 192.168.10.1
ip route 10.101.23.0 255.255.255.0 192.168.10.1
ip route 172.10.0.0 255.0.0.0 172.26.10.1
ip http server
--More-- ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
^C
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
yourname#
********** C1841 ******************
Current configuration : 1825 bytes
version 12.4
hostname Keppel
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
username cisco privilege 15 secret 5
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 192.168.100.2 255.255.255.252
duplex auto
speed auto
ip address 10.100.23.254 255.255.255.0
duplex auto
speed auto
ip http server
ip http access-class 23
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
When I do a traceroute from C1841 router,
1 192.168.10.1 0 msec 0 msec 0 msec
2 192.168.10.2 8 msec 4 msec 0 msec
3 * * *
4 * * *
I do further troubelshooting and realised the remote router can't access the HQ switch's uplink port, which link back to core switch. But I can't find any fault in the core switch.
Try a "show ip route" for the destinations you are trying to get to. I don't see any dynamic routing protocols, and I don't see enough static routes to get to the places you're trying to get to.
How are you crossing the VPN? Are you using a GRE tunnel or some other method to get to the other networks? Can you ping/trace to 192.168.100.1 or .2?
