craiglcve Thu, 09/20/2007 - 08:40
No, you cant rename a user. The user is generated by using the 'username create' command. You will need to delete the user and create a new one either through the GUI or command line.
mlitka Thu, 09/20/2007 - 09:17
Is there anyway to migrate the voicemail and greetings?
Markus Schneider Thu, 09/20/2007 - 10:52
  • Cisco Employee,
Not from one user to the next. Obviously you can change the user's name but not the user ID itself. If they don't use the CUE GUI, they may not even know/care about the actual user ID.
