wireless encryption between AP and Laptop
ankbhasi Sun, 09/23/2007 - 21:55
Hi Friend,
It depends on how you configure your WLAN/SSID. If it is configured for open authentication then there is no encryption and data is not secured between AP and clients but if you configure your SSID/WLAN and client with encryption technology as WPA1/2 with TKIP/AES you can get a secure communication between client and APs.
See if this link helps you
*Pls rate all helpfull post
Trending Topics - Security & Network
