09-20-2007 08:23 AM
I have 2 server (Svr1 & Svr2) and Load balncer (CSS-11503).
My question, is possible for load balance by port. I think this can work. But from client will access the server with different port let say port 1111 and 2222 (this just example). For 1111, client need directed to server, but for 2222 client access the vip in load balancer. So, is possible from client access to server directly and from client access to load balancer ?
Because on the server have 2 application interface, but 1 ethernet.
When access port 1111 no need load balanced but when access 2222 need load balanced. Is possible ?
09-21-2007 01:40 AM
Yes you can just specify 2 different content rules:
content loadbalance
vip address 172.16.4.123
add service server1
add service server2
protocol tcp
port 2222
active
content direct1
add service server1
protocol tcp
port 1111
active
content direct2
add service server2
protocol tcp
port 3333
active
09-22-2007 12:57 AM
hi diro,
thanks before.
But i want add information.
The condition like this :
1. Client must access to ServiceGuard Virtual IP. (This virtual ip from server side; svr1 and svr2).
2. Client must access to virtual ip on load balancer.
For Condition :
1. Client access (this sample) IP https://192.16.0.100:1111 > Client access ServiceGuard VIP.
2. Client access (this sample) IP https://10.16.0.200:2222 > Client access VIP Load Balancer. (10.16.0.200 map to 192.16.0.200)
From scenario on the above client access 2 IP,one in load baancer, one in server side (Service Guard VIP).
Is possible ? Client access to 2 different port but same server and different virtual ip.
How fo make configuration when client access to vip load balancer (this no problem), but client need access direct to server side.
Like the connection from client through CSS, and bypass by CSS.
I need configure 2 VIP on load balancer, for 1 VIP map to ServiceGuard VIP,or ???
09-24-2007 03:17 AM
This is what your looking for:
placing the loadbalancing in router mode.
the direct in derct server return that's why you need to turn of server nat.
content loadbalance
vip address 10.16.0.200
add service server1
add service server2
protocol tcp
port 2222
active
content direct1
no nat server
vip address 192.16.0.100
add service server1
protocol tcp
port 1111
active
content direct2
no nat server
vip address 192.16.0.200
add service server2
protocol tcp
port 3333
active
09-24-2007 03:46 PM
how for https, i think your configurations for http or can work with https.
how for configure :
from client should be access https://10.16.0.200:1111 to server
how configuration in load balancer, and in CSS not use SSL Module. Can this works. ?
can i get your email diro ?
