09-20-2007 08:41 AM - edited 03-14-2019 11:38 PM
Dear all,
I have CCM (v5.1.2 installation without DNS) and cisco 2811 (with ISDN PRI E1 trunk to PSTN) as a H323 GW, but 2811 doesn't seem to register with CCM.
In CCM I've configured router as H.323 type GW in the following way:
IP address/Device Name 10.0.9.10
Device Pool default
Call classification offNet
Location my_location
...the rest of parameters are default
The following is my 2811 config:
version 12.4
hostname ISDN_GW
boot-start-marker
boot-end-marker
card type e1 0 0
no logging buffered
enable secret 5 *****************
aaa new-model
aaa authentication login Terminal local-case
aaa authentication enable default line enable
aaa authorization config-commands
aaa authorization exec Terminal local
aaa session-id common
resource policy
network-clock-participate wic 0
ip subnet-zero
ip cef
ip host publisher 10.0.9.1
ip host subscriber 10.0.9.2
ip host ISDN_GW 10.0.9.10
isdn switch-type primary-net5
voice-card 0
dspfarm
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 3
username admin privilege 15 password ***
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
interface FastEthernet0/0
ip address 10.0.9.10 255.255.255.224
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id publisher ipaddr 10.0.9.1 1720
h323-gateway voip h323-id ISDN_GW
h323-gateway voip bind srcaddr 10.0.9.10
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
isdn incoming-voice voice
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.9.30
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
dial-peer voice 1000 voip
destination-pattern .T
voice-class codec 1
voice-class h323 1
session target ipv4:10.0.9.1
dtmf-relay h245-alphanumeric
no vad
gateway
timer receive-rtp 1200
line con 0
exec-timeout 60 0
logging synchronous
login authentication Terminal
transport output all
stopbits 1
line aux 0
exec-timeout 60 0
logging synchronous
line vty 0 4
exec-timeout 60 0
logging synchronous
transport input telnet ssh
line vty 5 15
exec-timeout 60 0
logging synchronous
scheduler allocate 20000 1000
ntp clock-period 17179861
ntp update-calendar
ntp server 10.0.9.1 source FastEthernet0/0 prefer
ntp server 10.0.25.1 source FastEthernet0/0 prefer
end
When I type show gateway, I get the following output
ISDN_GW#show gateway
H.323 ITU-T Version: 4.0 H323 Stack Version: 0.1
H.323 service is up
Gateway ISDN_GW is not registered to any gatekeeper
Alias list (CLI configured)
H323-ID ISDN_GW
Alias list (last RCF) is empty
H323 resource thresholding is Disabled
Does Cisco CallManager can act as an H.323 gatekeeper? If yes, how CCM should have to be configured for that purpose?
Can somebody point me out where I'm wrong?
TIA
Zoran Milenkovic
Solved! Go to Solution.
09-20-2007 09:21 AM
Actually H323 GW dont register to CCM.
They act as peer to peer.
MGCP do register.
CCM cannot act as a GK.
We use Locations as a CAC mechanism.
09-21-2007 04:03 PM
Hi Zoran,
Dont worry about domains, you just add in CCM under Device H323 GWs.
And in the GW add dial-peers.
Please let me know what exactly you are trying to do.
09-20-2007 09:21 AM
MGCP do register.
09-20-2007 11:04 AM
Dear gogasca!
Thanks for quick reply. Can you point me out how can I check out is everything ok with my config? Some debug command?
Also, I don't understand how to define H323 IDs of CCM and 2811 in no DNS service environment? The format of ID is email format, but I'm confused what would be my domain part since we have no defined domain?
TIA
Zoran Milenkovic
09-21-2007 04:03 PM
Hi Zoran,
09-23-2007 03:00 AM
It's clear now! Thank you!
Obviously, I was pretty new to H.323 GWs and CCM. I was confused mainly by unknown status of H323 GW in CCM.
Now after your posts and few PDF books, I understand much better the relationship between CCM and H323 GW.
Also, I've realized that I don't need Gatekeeper nor DNS. My Fa0/0 is now configured this way:
duplex auto
speed auto
My problem is probably in dial-peers, but I'll start the new thread as soon as I formulate a question.
BR
Zoran Milenkovic
09-21-2007 01:13 PM
Are you experiencing a failure? I've never seen a H323 GW register to CCM. CCM doesn't act as a gatekeeper. An H323 GW doesn't need to "register" to CCM in the same way a MGCP GW does in order to work correctly. Hope that helps.
