Do you have to copy run start for simulation questions
Sep 20th, 2007
I jus failed BSCI and I know I got both simulations correct, but I just remembered I forgot to copy run start - does anyone know for a fact whether this makes your answer correct or incorrect?
greekgeek Thu, 09/20/2007 - 12:03
I did a "write terminal" at the end of one of my simulations today and the test told me that command wasn't supported. I'm not sure if copy run start would have taken...I didn't try it.
My exam was the 640-801.
tperrier Fri, 09/21/2007 - 01:40
  • Silver, 250 points or more
If they don't ask you to save the config, you don't have to. Simple as that.
steve-gates Fri, 09/21/2007 - 07:07
I got into the habit of using copy run start after config changes and applied this on all my exams...not sure if it helps on the sims but is good practice to get into when working in general..
Steve
srue Fri, 09/21/2007 - 09:43
  • Blue, 1500 points or more
it doesn't hurt.
but to be honest - NOBODY but the exam writers knows without doubt if this affects your final score.
