access-list problems on 1840
Answered Question
Sep 20th, 2007
hi,
I have cisco 8140 router.
The problem is that users can't go to the internet but from the router itself i can ping external ip address.
I have the following routing
p classless
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xx
ip route 10.0.0.0 255.0.0.0 172.30.21.100
ip route 192.168.0.0 255.255.255.0 172.30.61.100
and the following access-list
access-list 3 permit xxx.xx.xx.xx log
access-list 3 permit 192.168.0.0 0.0.255.255 log
access-list 100 permit ip 192.168.30.0 0.0.0.255 any
what iam doing wrong?
Thank you for any replays
Correct Answer by Richard Burts about 9 years 3 months ago
Bar
There is not enough information here for us to know quite what the problem is. If you can provide some more information telling us which interface is facing inside and what its address and subnet are, which interface is facing outside and what its address and subnet are. Also you have given us two access lists but have not told us on which interface and in what direction they are applied.
If we know the things that I have asked we may be able to identify your problem.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Thu, 09/20/2007 - 10:55
Bar
Rick
visteknetworking Thu, 09/20/2007 - 12:40
Hi Rick,
Thank you for your prompt reply.
The issue has been resolved.
The problem was with the in nat source which i didn't specify
any way thank you
Richard Burts Thu, 09/20/2007 - 12:55
Bar
I am glad that you got it working. Thank you for posting back to this thread and indicating that it is fixed and how you fixed it. Thank you for using the rating system to indicate that the problem is resolved (and thanks for the rating). It makes the forum more useful when people can read about a problem and can know that they will read about what solved the problem.
Rick
