Control Error [201]
Sep 20th, 2007
When I try to login with my profile (extension mobility) on Cisco 7970, I get error message "Control Error [201]". Can someone help me how to slove this issue? I'm using CallManager 6.0.
Thanks.
gogasca Thu, 09/20/2007 - 16:40
  • Green, 3000 points or more
Have u already follow the configuration guide?
Only for 7970s?
The template is for the same phone model?
ysanadiga01 Thu, 09/20/2007 - 22:26
I'v configured two profiles and one of them is working without any problem. I just copied the profile, which is working correctly, and changed the name and configured a separate line number on it. I tried to login on a different telephone model, but all in vain.
gogasca Thu, 09/20/2007 - 22:43
That makes sense to me.
Device Profiles are based on Phone models also.
Make sure when u login the Phone model and the Device Profile are using to login are the same otherwise it will fail.
