WebVpn on IOS. Problem When access files on network
Sep 20th, 2007
I have a router 2811 with WebVpn enabled but when clients connect on it them can not access files inside the network. and after trying to access all access stop working, ping terminal service etc.
If I issue a normal ping it goes well and keep working for a long time, if I issue an ping with 4096 payload it does not respond and the webvpn stop working and the clients have to disconnect and connect again.
guibarati Fri, 09/28/2007 - 12:29
Answering myself, It's an IOS bug and I needed to disable "webvpn cef" as a workaround to get it working.
