WLC 4400 and multiple authentication servers e.g. RADIUS, ACS
rcullum Thu, 10/11/2007 - 14:40
ACS is a radius server, as well as TACACS+. The WLC can be set up to use one radius server for user auth, and another for WLC admin auth.
Jagdeep Gambhir Thu, 10/11/2007 - 14:53
Yes, that is correct. You can set acs to use both radius and tacacs.
For this you need to add WLC twice in acs-->network configuration. But you need to keep host name different.
eg 1) Host name WLC --->IP x.x.x.x -->Auth using -->radius
2) Host name WLC1--->IP x.x.x.x --->Auth using -->Tacacs.
You need to set up tacacs commands on WLC along with radius commands.
Please rate helpful posts
Trending Topics - Security & Network
