Policy Based Routing
Sep 20th, 2007
We are having a terrible time. We have a 3550 with the enhanced image. IT has a default gateway of an existing firewall. We have added a 2nd firewall and ISP. If the traffic is HTTP traffic, we want to point it to the NEW ISP AND FIREWALL. We thought PBR would solve this but the ip policy interface command does not exist in 12.1(22)EA1. IS there any other way to accomplish this such that I point HTTP traffic out another direction? PLEASE HELP!!!!
Overall Rating: 5 (2 ratings)
Edison Ortiz Thu, 09/20/2007 - 18:10
  • Hall of Fame,
    Founding Member
Source based routing can only be accomplished with PBR.
According to the Feature Navigator, 12.1(22)EA1 does support PBR (the EMI IOS IMAGE) c3550-i5q3l2-mz.121-22.EA1.bin
However, you must change your SDM template from 'desktop' which is the default to 'routing'.
Look for the global config command 'sdm prefer'. A reboot is required after this change.
netsec123 Thu, 09/20/2007 - 18:25
You're kidding!
I tried that. Would you know the exact SDM Command? I did the reboot too! When I go into the vlan1 interface and type ip ??, there is no ip policy command. :( Do you know the exact SDM command I need?
THANKS!
netsec123 Fri, 09/21/2007 - 14:49
Thank you for getting back to me.
This is killing me! Take a look at the output below and I will comment .. As you can see, the command is NOT listed, I put in the SDM statements, rebooted twice, and also listed a show ver on the switch! IP routing is enabled. I don't get it... I gotta be missing something stupid... Please help.... THANKS!
cef Cisco Express Fowarding interface commands
dhcp Configure DHCP parameters for this interface
directed-broadcast Enable forwarding of directed broadcasts
helper-address Specify a destination address for UDP broadcasts
irdp ICMP Router Discovery Protocol
load-sharing Style of load sharing
local-proxy-arp Enable local-proxy ARP
mask-reply Enable sending ICMP Mask Reply messages
mtu Set IP Maximum Transmission Unit
probe Enable HP Probe support
proxy-arp Enable proxy ARP
rarp-server Enable RARP server for static arp entries
redirects Enable sending ICMP Redirect messages
rip Router Information Protocol
route-cache Enable fast-switching cache for outgoing packets
security DDN IP Security Option
split-horizon Perform split horizon
summary-address Perform address summarization
unnumbered Enable IP processing without an explicit address
unreachables Enable sending ICMP Unreachable messages
vrf VPN Routing/Forwarding parameters on the interface
HaddRouter(config-if)#ip policy ?
% Unrecognized command
sdm prefer routing extended-match
IOS (tm) C3550 Software (C3550-I9Q3L2-M), Version 12.1(22)EA1a, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 20-Aug-04 00:30 by yenanh
Image text-base: 0x00003000, data-base: 0x006C5C6C
ROM: Bootstrap program is C3550 boot loader
HaddRouter uptime is 2 hours, 32 minutes
System image file is "flash:c3550-i9q3l2-mz.121-22.EA1a/c3550-i9q3l2-mz.121-22.E
A1a.bin"
cisco WS-C3550-48 (PowerPC) processor (revision Q0) with 65526K/8192K bytes of m
emory.
Processor board ID CAT0846N0M0
Last reset from warm-reset
Running Layer2/3 Switching Image
Edison Ortiz Fri, 09/21/2007 - 14:55
  • Hall of Fame,
    Founding Member
You have c3550-i9q3l2-mz.121-22.EA1a and Cisco Feature Navigator list the supported IOS as c3550-i5q3l2-mz.121-22.EA1.bin
Please download such IOS and try again.
netsec123 Fri, 09/21/2007 - 17:27
THANK YOU.
I WILL TRY THIS IMMEDIATELY!
Thank u so much!
netsec123 Fri, 09/21/2007 - 17:52
(fc1)
A1a.bin"
emory.
netsec123 Fri, 09/21/2007 - 18:14
Uh oh ..... Turns out I have an SMI switch ... Am I hosed...
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:12:80:43:AE:80
Motherboard assembly number: 73-5701-10
Power supply part number: 34-0967-02
Motherboard serial number: CAT084606YY
Power supply serial number: DTH08456JMV
Model revision number: Q0
Motherboard revision number: A0
Model number: WS-C3550-48-SMI
System serial number: CAT0846N0M0
Configuration register is 0x10F
Edison Ortiz Fri, 09/21/2007 - 18:38
  • Hall of Fame,
    Founding Member
Indeed, you are :)
You need EMI ...
netsec123 Sat, 09/22/2007 - 05:16
Thank you --- I missed that...
BUT, thank you so much for your help. I will bring in another router with a single ethernet and reroute packets that way... Waht would happen if I tried to install the EMI image on the SMI switch?
netsec123 Sat, 09/22/2007 - 08:15
Thank you sir. I will not try this remotely! :) I will use another router. IN ANY CASE THANK YOU SO MUCH!
You rock!
Cheers!
