Call Manager Express VOIP calls
Sep 20th, 2007
I have call manager express configured and i'm able to make calls from one lan to another. i'm not able to get calls to roll to voicemail unless they are VOIP calls made on the same lan. any suggestions? voicemail is configured. if i configure a dial peer for the 2nd systems service engine, i can access voicemail on system 2, but calls will not roll to voicemail. HELP.
paolo bevilacqua Mon, 09/24/2007 - 09:03
  • Hall of Fame,
    Founding Member
do you have codec g711 for the voip DP pointing to CUE (either local or remote) ?
How do you 'roll' calls to VM ?
waynedyer12 Mon, 09/24/2007 - 09:10
i actually figured it squared away...i was missing the h323 to sip command
paolo bevilacqua Mon, 09/24/2007 - 12:01
  • Hall of Fame,
    Founding Member
Also If you configure the IP addressof the CUE to be 'borrowed' off one LAN interface, using ip route x.x.x.x 255.255.255.255to service module, you should be able to have SIP DP's pointing directly to CUe's address.
