Cisco IP communicator
dsriniva
I have an application(X) that runs on port 80.when i use both Cisco IPC & application(X)simultaneously, Cisco IPC disables that application(X)...is Cisco IPC using the same port 80?
gogasca
Level 10
Level 10
CIPC have a webserver running.
You can disable it from regedit.
you can disable the web service on CIPC by importing the following reg file:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems, Inc.\Communicator]
"WebServerDisabled"=dword:00000001
