Error in 7825 H2
Sep 21st, 2007
Hi All,
we are facing the problem while installing CCM4.x in 7825 H2. The error message comes "CPU speed fatal error". The CPU speed detected was not the expected 2800MHz.Actual detected CPU speed 3400MHz.Please correct before reattempting the installation .
Pls. advice.
regds,
aman
Rob Huffman Fri, 09/21/2007 - 05:18
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Aman,
What OS version are you trying to install?
Rob
gogasca Sun, 09/23/2007 - 23:52
  • Green, 3000 points or more
Hi Aman
Which OS version?
Did you buy the server with us or with HP directly_?
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure0900aecd8062a4f9.html
Here are supported servers:
MCS-7825-H2-IPC1
2.8 GHz
MCS-7825-H2-IPC2**
3.4 GHz
For CCM 4.2 you need at least:
No minimum SQL 2k requirement and OS 2000.4.2sr2 required prior to upgrade
amansoi_5 Mon, 09/24/2007 - 20:34
Hi Gogasca,
the problem got resolved.
We were under the impression that with new CCM , Software CDs have not been ordered .So, we were trying to install with older CDs.
After we were able to locate the new CD software which came with new CCM , installation of Wondows OS was smooth. CCM installation yet to be done.
regds,
aman
