Remote user routing issue
Sep 21st, 2007
I have a remote user who connects in and when they try and connect to lan behind the firewall I am seeing a message in the asdm
flow is a loopback
and tears down the connection.
here is the actual log.
any help greatly appreciated.
6 Jan 07 1993 13:45:00 302014 Teardown TCP connection 1081682 for outside: to outside: duration 0:00:00 bytes 0 Flow is a loopback
Kevin Dorrell Fri, 09/21/2007 - 03:41
Are you saying that is supposed to be behind the firewall? Is that what the routing says?
darkbeatzz Fri, 09/21/2007 - 04:16
yes. is the lan behind firewall and is the pool assigned to vpn users
darkbeatzz Fri, 09/21/2007 - 06:43
I have resolved this. bad route in the routing table.. thanks anyway
