PPTP between CPE and PE
Sep 21st, 2007
We need to run PPTP between our CE and PE so that we can bill the customer based on their usage. Is it a way to configure PPTP between two routers and if so can someone provide me the related path?
arun kumar Sun, 09/23/2007 - 20:42
hi prem,
we are already using L2TP..
but we need to chk the same can be done by PPTP.. if you have any documents for doing this by PPTP kindly provide the info...
thanks for your reply...
arun kumar Mon, 09/24/2007 - 21:29
hi CAN someone clarify whether PPTP can be created between two routers instead between a client (normally a PC) and a router?? If so pls provide some docsw
