I can not activate the VWIC2-2MFT-T1/E1 card on a cisco 2821 router
Sep 21st, 2007
Hi all,
I have a Cisco 2821 ROUTER on which I connect a VWIC2-2MFT-T1/E1 card . The problem is that the IOS does not recognize the command "card type E1".
Can someone help?
Please See below the result of the sh ver command on this router:
sonl01-28rt03-pr#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(3f)
RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 18-Aug-06 18:47 by alnguyen
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
sonl01-28rt03-pr uptime is 9 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.124-3f.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2821 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FCZ103570HM
2 Gigabit Ethernet interfaces
2 Channelized (E1 or T1)/PRI ports
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
spremkumar Fri, 09/21/2007 - 04:53
hi
can you try card type e1 x (x slot number where the card is installed) ?
regds
implementation_ipt Fri, 09/21/2007 - 07:09
The problem is that I do not see the command "card" when I type "?" on the configuration mode, thus When I type the "card type e1 x " command the router replies me that this is an unknown command.
Thanks for your help!
specialed351 Fri, 09/21/2007 - 07:52
are you saying that the serial interfaces aren't showing up or the controllers?
pstebner1 Fri, 09/21/2007 - 09:51
I'm pretty sure that tyhe card-type command does not apply to VWICs. You can accomplish the config by using the "controller e1 0/0" (or whichever controller it is) command,
and then entering you framing type, etc.
hth,
Paul
wochanda Fri, 09/21/2007 - 10:56
Is the router recognizing the cards? Please provide 'show diag'.
pstebner1 Fri, 09/21/2007 - 11:31
what slot do you have the VWIC in?
edit: Have you tried another slot? Also, that IOS is rather old. Have you considered updating it?
Also, Specialed351, my 2811 does show my VWIC-2MFT-T1 on a sh diag.
P
specialed351 Fri, 09/21/2007 - 11:34
but the router does see the card in the "show ver". Did you try the command even though it does not show? there are some commands that do not show on a "?"...if it is true e1 t1 you have to specify.
cyber-burn Fri, 09/21/2007 - 19:47
More then likely you have a bad slot in the router or a bad vwic. I had the same problem with one of my 2820s and I had to have TAC replace the vwic. I try moving the vwic to another slot. If that doesn't work, its probably bad.
