Replacing VWIC-1MFT-T1 with E1
Sep 21st, 2007
I have a CME system which has installed a VWIC-1MFT-T1. The configuration has been completed with this card. It turns out the customer needs a VWIC-1MFT-E1. Is there anything I should be aware of when swapping these over?
I would usually save the running config, power down, replace the VWIC, then power up. Is there anything I would need to do before powering down to remove the vwic-T1 from my config? Would anything in the config interfere with the new VWIC-E1? What, if any, sections would be changed/removed?
This is the first time i've done a switch like this and i'm trying to make it go as smooth as possible.
Thanks for looking.
David
