aironet 1200 /1240 problem
Sep 21st, 2007
I have the following problem with my APs.
I use snmpset to change an object's value. I set
the new value succesfully, but when i try to get the new value the snmp agent returns the old value.
setting....
[email protected]:/home/teo# snmpset -v 2c -c demopublic 192.168.1.11 CISCO-DOT11-IF-MIB::cd11IfDesiredSsidMaxAssocSta.1 u 2
the agent reports the new value....
CISCO-DOT11-IF-MIB::cd11IfDesiredSsidMaxAssocSta.1 = Gauge32: 2
here is the problem....
[email protected]:/home/teo# snmpget -v 2c -c demopublic 192.168.1.11 CISCO-DOT11-IF-MIB::cd11IfDesiredSsidMaxAssocSta.1
CISCO-DOT11-IF-MIB::cd11IfDesiredSsidMaxAssocSta.1 = Gauge32: 255 <======== the old value ======
I have tried snmpset with other objects and it works fine.
gmarogi Thu, 09/27/2007 - 09:55
  • Bronze, 100 points or more
From where did you try to set the snmp values?. Is it from WLSE? or if it is a light weight AP, did you try this with the WCS?
Trending Topics - Security & Network
