basic throughput calculations
Answered Question
Hi all,
I am doing some basic calculations for time it should take to transfer a file over my network. apparently its been a while since I had to do math as I am doubting myself!
I just wondered how long it would take to transfer my 90GB file over a network connection that I knew to be 800Mbps.
So I did the following:
1Mbps = .125MBps
800Mbps * .125MBps = 100MBps
So thats 100 meg a second correct?
1000Mb = 1GB
90000MB = 90GB
at that rate it should take roughly 900 seconds to transfer the 90GB file..or 15 minutes. is this right?
TIA,
R
Correct Answer by Joseph W. Doherty about 9 years 6 months ago
Your basic calculations are correct for time to transmit 90GB across 800 Mbps. In practice, due to frame/packet overhead, and how well stack deals with BDP (bandwidth delay product), actual transmission time might be considerably slower than the calculated value.
Overall Rating: 5 (1 ratings)
Correct Answer
Joseph W. Doherty Fri, 09/21/2007 - 07:20
