2811 router no external dial
I have configure a Cisco 2811 with CCME 4.0
I use QCT to configure the router.
I just want to test this platform, with 2 IP Phone (7911)
All is not working. Internal call is OK.
But External call is not OK.
In QCT i have select 0 for prefix (to call Outside) ISDN BRI Card
When I try to call external using 0, i have Unknown Number. Phone accept only the number 2 (2xx internal number).
1) Dialplan problem ?, or BRI Interface problem ?
Thanks for your help
I have Add the configuration in Attachements
Anonymous (not verified) Thu, 09/27/2007 - 08:28
It is due to conflicting dial plan. Use 9 to access external number and internal operator extention as "0"
singhcisco Thu, 09/27/2007 - 14:52
Hello, Under telephony-service enter
secondary-dialtone 0 (Zero) and then;
cre cnf-files
and reset your phones. This should resolve your issue.
Paolo Bevilacqua Thu, 09/27/2007 - 14:56
If your country dial-plan allows (I think france does), you can also avoid using the prefix digit for external calls altogether. Do make your extensions begin with 2 or any digit not used nationally.
The effect is that you can redial more easily (no need to change numbers), dial is faster and more intuitive, and is generally favorably accepted by users.
