Route Pattern Configuration (CCM 5.1)
Sep 21st, 2007
I had a feedback from a client that it is quite interesting. He is using a CCM Version 5.1 and was wondering if the Route Pattern could be disabled on the CCM configuration page. Apparently, this is not possible, is it in other version or is there any roadmap ?
That would be very interesting in order to avoid using a particular Route Pattern without deleting it.
Thanks for your reply,
Laurent IGNATIO
Overall Rating: 5 (1 ratings)
mchandak Fri, 09/21/2007 - 12:41
  • Gold, 750 points or more
AFAIK, this is currently not on RoadMap. One thing you can try to do is create a dummy MGCP Gateway and assign it on the Route Pattern. This should unregister the Route Pattern from Dial Analysis.
Hope this helps
