Unity4.2.1, installed dual language but only one
Answered Question
Sep 21st, 2007
I installed ENC and FRA both but I able to see only English from subscriber conversation and call handler.
-Language license=2
-I have three directory on \localoze\defaultconfiguraito\
1)ENC
2)ENU
3)FRA
why I able to see English only from the language selection even installed FRA?
Thanks in advance,
Correct Answer by Rob Huffman about 9 years 6 months ago
Hi John,
It looks like the old 3 - Languages 2- License's issue. Try selecting FRA via this method;
The number of language licenses available determines how many phone, TTS, and GUI languages Cisco Unity can load and use at a time. For example, if your organization has two phone language licenses, but has four languages installed, Cisco Unity will allow you to load and use only two at any one time. You can, however, select which two are used, and you can change this selection at any time. This flexibility allows you to better manage the language needs of your users.
Specifying Phone Languages
You specify a default phone language and other system-wide phone language settings on the System > Configuration > Phone Languages page.
From this good older doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/402/administration/guide/ex/SAG_0090.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Fri, 09/21/2007 - 06:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi John,
Hope this helps!
Rob
Rob Huffman Fri, 09/21/2007 - 07:13
  • Hall of Fame,
    Founding Member
You are most welcome John:)
Take care,
Rob
