URGENT - problem with Cisco 876 and ADSL over ISDN
Sep 21st, 2007
I'm having problems with a Cisco 876 router. I have configured the router and when I connect the line to ADSLoverISDN interface and ATM interface seems to get up for 2 seconds then goes down.I cannot get a connection no matter what. Here is the configuration in case there is something wrong with it:
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
vpdn enable
vpdn-group 1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 1/35
encapsulation aal5snap
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxxxxx
ppp chap password 0 xxxxxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
Can anyone help me with this as it's quite urgent?
IgorHamzic Fri, 09/21/2007 - 07:46
Here is the debug atm events:
*Mar 1 04:15:25.095: DSL: Received response: 0x41
*Mar 1 04:15:30.375: DSL(ATM0): ADSL_ID_NACK_EXT, error code 0x81 at Far End
*Mar 1 04:15:30.375: DSL: Get FAR End Modem Vendor ID Failed
*Mar 1 04:15:30.375: Matching SAR to Line speed: Attempt number 1
cps 1 slots 21
APL Level 0 slots 21
APL Level 1 slots 21
*Mar 1 04:15:30.375: ATM0: atmsar_get_plim_info
*Mar 1 04:15:30.375: ATM0:atmsar_update_plimtype
*Mar 1 04:15:30.375: ATM0 atmsar_update_us_bandwidth(): upstream bw =634 Kbps
*Mar 1 04:15:30.379: DSL: SM: [DMTDSL_DO_OPEN -> DMTDSL_SHOWTIME]
*Mar 1 04:15:32.879: ATM0 DSL: Defect: LOM
*Mar 1 04:15:32.879: DSL: Defect: LOS LOF LCDf: retraining
*Mar 1 04:15:35.067: ATM0: atmsar_vc_dlcx
*Mar 1 04:15:35.067: (ATM0)1a_enable: delay activation of vcd=1, vc=0x82E91F20
*Mar 1 04:15:35.067: atmsar enable ATM0
*Mar 1 04:15:35.067: ATM0: atmsar_bringup_interface: Interface and atm_db flags are UP
*Mar 1 04:15:35.379: atmsar_atm_lineaction(ATM0): state=0
*Mar 1 04:15:35.379: DSL: SM: [DMTDSL_SHOWTIME -> DMTDSL_RE_OPEN]
*Mar 1 04:15:35.379: DSL: Send ADSL_CLOSE command.
*Mar 1 04:15:35.379: DSL(ATM0): Sent command 0x4
*Mar 1 04:15:36.847: DSL: Received response: 0x25
*Mar 1 04:15:36.847: DSL: Connection closed
*Mar 1 04:15:36.847: DSL: SM: [DMTDSL_RE_OPEN -> DMTDSL_DO_OPEN]
*Mar 1 04:15:36.847: DSL: Send ADSL_OPEN command.
*Mar 1 04:15:36.847: DSL(ATM0): Using subfunction 0x0
*Mar 1 04:15:36.847: LOCAL:Max noise margin for power cutoff 31
*Mar 1 04:15:36.847: DSL(ATM0): Sent extended command 0x3
*Mar 1 04:15:39.347: DSL(ATM0): 1: Modem state = 0x9
*Mar 1 04:15:41.847: DSL(ATM0): 2: Modem state = 0x9
*Mar 1 04:15:44.347: DSL(ATM0): 3: Modem state = 0x10
*Mar 1 04:15:45.067: ATM0: atmsar_vc_dlcx
*Mar 1 04:15:46.847: DSL(ATM0): 4: Modem state = 0x10
*Mar 1 04:15:49.347: DSL(ATM0): 5: Modem state = 0x10
*Mar 1 04:15:51.847: DSL(ATM0): 6: Modem state = 0x10
*Mar 1 04:15:54.347: DSL(ATM0): 7: Modem state = 0x10
*Mar 1 04:15:56.847: DSL(ATM0): 8: Modem state = 0x10
*Mar 1 04:15:56.979: DSL: Received response: 0x24
*Mar 1 04:15:56.979: DSL: Showtime!
*Mar 1 04:15:56.979: DSL(ATM0): Sent command 0x31
*Mar 1 04:15:56.991: DSL: Received response: 0x12
*Mar 1 04:15:56.991: DSL(ATM0): operation mode 0x2000000
*Mar 1 04:15:56.991: DSL(ATM0): Sent command 0x33
*Mar 1 04:15:56.995: DSL: Received response: 0x16
*Mar 1 04:15:56.995: DSL(ATM0): Far End Chip Country Code 0xFF
*Mar 1 04:15:56.995: DSL: Far End Chip Vendor ID GSPN
*Mar 1 04:15:56.995: DSL: Far End Chip Vendor ID Specific 0x0310
*Mar 1 04:15:56.995: DSL: Far End ITU Vendor STD Number 0x0003
*Mar 1 04:15:56.995: DSL(ATM0): Sent command 0x32
*Mar 1 04:15:57.003: DSL: Received response: 0x14
*Mar 1 04:15:57.003: DSL(ATM0): Near End Chip Country Code 0x0F
*Mar 1 04:15:57.003: DSL: Near End Chip Vendor ID STMI
*Mar 1 04:15:57.003: DSL: Near End Chip Vendor ID Specific 0x0000
*Mar 1 04:15:57.003: DSL: Near End ITU Vendor STD Number 0x0003
*Mar 1 04:15:57.003: DSL(ATM0): Sent extended command 0x5
*Mar 1 04:15:57.011: DSL(ATM0): Near End Modem Country Code 0xB5
*Mar 1 04:15:57.015: DSL: Near End Modem Vendor ID CSCO
*Mar 1 04:15:57.015: DSL: Near End Modem Vendor ID Specific 0x0000
*Mar 1 04:15:57.015: DSL: Near End Modem Version 12.4(4)T7`
*Mar 1 04:15:57.015: DSL: Near End Modem Serial Number FCZ112752TT
*Mar 1 04:15:57.015: DSL(ATM0): get Near End extended ITU ID succeeded
*Mar 1 04:15:57.015: DSL(ATM0): Sent extended command 0x5
*Mar 1 04:15:58.987: DSL: Received response: 0x41
*Mar 1 04:16:05.903: DSL(ATM0): ADSL_ID_NACK_EXT, error code 0x81 at Far End
*Mar 1 04:16:05.903: DSL: Get FAR End Modem Vendor ID Failed
*Mar 1 04:16:05.903: Matching SAR to Line speed: Attempt number 1
cps 1 slots 22
APL Level 0 slots 22
APL Level 1 slots 22
I just can't get the PCs to connect to the internet.
nikhil_kapoor Sun, 09/23/2007 - 07:14
Hi ,
I can see some commands missing in your config . Pls try to congiure them and try . Pls change the MTU to 1440as by deafult for TAM its 1440 . Where as i cant see vbr-nrt configured under pVC .
you configure your desired B.W
e.g :Vbr-nrt 128 128 1
interface ATM0
no ip address
pvc 1/35
vbr-nrt 128 128 1 <<<<<<<<<<<<<<
interface Dialer1
mtu 1440 <<<<<<<<<<<<<<<
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
If still there is some issue with ATM then check the Tx path etc last hope replace the ATM card of the router .
HTH ... Cheers NK
