Using loopback address for return packets
Sep 21st, 2007
We have setup our voip dial-peers to use the loopback address with the 'voice-class source" command. Thats ok for one direction. Now how do we setup the receiving end to use its loopback address. Is there some command to put on the dial-peer pots entry to force the use of the loopback address on the return packets.
PS In case you have not noticed I know next to nothing about voice, so please forgive if this is an easy, straight forward question.
lagos Sun, 09/23/2007 - 09:12
These commands on your loopback interface will source all H323 traffic from the loopback. You do not need the dial-peer voice-class command.
h323-gateway voip interface
h323-gateway voip bind srcaddr x.x.x.x
HTH.
jogillis Mon, 09/24/2007 - 12:22
There is no h323 gateway explisitly defined anywhere in the config.
jogillis Thu, 09/27/2007 - 10:29
Thanks for the replies. I do not know enough to know whether I am using H.323 or sip. Will try the suggestions.
