cm 4.2 XML Parse Error - Corporate Directory 7970 Phone
ischarcm
Using load SCCP70.8-3-2SR1S for the 7970, CUCM 4.2 I am getting an XML Error when searching names in corp directory... Anyone else getting anything similar, any ideas?
gogasca
Level 10
Level 10
Looks like: CSCsg24774
Directory searches with results greater than 32 characters for the last name and first name combined result in an XML Parse error.
This should be already solved.
It happens for all directory searches or only large names?
If you use a different load it works?
Lets say: cmterm-7970_7971-sccp.8-3-2.
I've the same problem! Some names are displayed, but if I search for example: FAX the result is "XML [4]: Parse Error". But I search EDU, the system show me correctly. Someone can Help us?
