How do I add extra IP addresses to my WAN side interface on my ASA 5505
Sep 21st, 2007
I have 8 IP addreses from my ISP. I want to use two of them on my new ASA 5505. I have configured one of the interfaces with our primary IP address but want to add a second. How do I set up the ASA 5505 to use more than one IP address on the same WAN Interface?
Overall Rating: 4 (1 ratings)
srue Fri, 09/21/2007 - 09:39
you use them with nat. and then if you need to allow inbound access to one of those addresses, you need to create an inbound acl.
ken.bartlett Fri, 09/21/2007 - 09:56
Thanks. Now,,,, how do I "use them with nat"? Could you please elaborate? I'm new to the 5505.
And,,, could you please explain how I "create an (appropriate) inbound acl"?
srue Fri, 09/21/2007 - 20:17
As you can see from the links I provided, there are plenty of people doing that already. I see no need to reinvent the wheel - or hold people's hands as the case may be. Maybe I incorrectly assumed that as an "IT Manager" you had the motivation to read the actual documentation. I guess I was wrong.
