Bad disk0:/ (onboard flash) on ASA
Sep 21st, 2007
Hello, I was wondering if anyone knows the configuration registry code to force an ASA to boot from the saved configuration on a flash drive? I'm looking for a 0x? solution. Any help would be appreciated!!
whisperwind Fri, 09/21/2007 - 10:05
I am unaware of the ability to use the usb flash drive not are there any 0x commands I am aware of.
Closest you can get is the password recovery procedure but even that will not give you exactly what you are asking.
alonzo.garza Fri, 09/21/2007 - 11:58
Well, what I'm trying to do is to force it to boot and get its config from disk1:/ which is a small 512MG SANDISK Compact Flash card. Currently the config shows the following:
boot system disk0:/asa722-k8.bin
boot config disk0:/TFTP/10.10.10.40/asa722-k8.bin
I can't change that once I boot because the onboard flash is damanged, so now I have it booting from a TFTP server but I also want to force it to load the config. I guess I should just send them off for RMA huh?
I want to force it to have this config:
boot system disk1:/asa722-k8.bin
boot config disk1:/TFTP/10.10.10.40/asa722-k8.bin
I don't see how though since it won't save any configurations my TFTP workaround is not working :-( Thanks anyway
