bgp community number
Answered Question
Sep 21st, 2007
when I do a sh ip bgp community ? I get the following on two routers.
route-views.oregon-ix.net>sh ip bgp community ?
aa:nn community number
local-AS Do not send outside local AS (well-known community)
no-advertise Do not advertise to any peer (well-known community)
no-export Do not export to next AS (well-known community)
| Output modifiers
<cr>
jo100-r5>sh ip bgp comm
jo100-r5>sh ip bgp community ?
<1-4294967295> community number
| Output modifiers
<cr>
one router has a community number <1-4294967295> and the other one has aa:nn
what is the difference? Is it IOS feature?
Correct Answer by Pavel Bykov about 9 years 7 months ago
Yes, this is an IOS feature. The first router has what is called a "new format" of BGP community. They are both 32 bit numbers, but in "new format" the community is specified in "aa:nn" where "aa" is your AS number and "nn" is an arbitrary number. It was created for practival purposes, because 65000:1 was easier to write and manage than for example 3128683542.
To turn on or off the new format feature use "ip bgp-community new-format" global configuration command.
Hope this helps.
Please rate all helpful posts.
Correct Answer by Richard Burts about 9 years 7 months ago
Chandra
Yes it is an IOS feature. You can use the command ip bgp-community new-format to have the router format the community with the AS:value format.
Rick
Overall Rating: 5 (2 ratings)
Correct Answer
Richard Burts Fri, 09/21/2007 - 10:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Chandra
Rick
Correct Answer
Pavel Bykov Fri, 09/21/2007 - 10:39
  • Silver, 250 points or more
Hope this helps.
Harold Ritter Fri, 09/21/2007 - 10:39
  • Cisco Employee,
Chandrathilaka,
The following command is configured on the first but not on the second router:
R1(config)#ip bgp ?
new-format select aa:nn format for BGP community
