ACL NAT ICMP Confusion
Sep 21st, 2007
Riddle me this.....
Given an ACL that has the following line in it:
access-list TEST-NONAT extended permit icmp host EDISRV host X.X.X.X
When I attempt the following I get this error message:
ASA(config)# nat (INSIDE) 0 access-list TEST-NONAT
ERROR: access-list has protocol or port
At which point I scratch my head and say "well of course the acl has a protocol and port"
If I remove the ACL line I posted above the nat statement is accepted just fine.
I do not understand why.
Jon Marshall Fri, 09/21/2007 - 10:33
You cannot use a port in an access-list that is there for NAT exemption.
You can use ports in access-lists for policy NAT.
whisperwind Fri, 09/21/2007 - 10:53
Come on srue that is not helpful at all.
Why does exempting ping something is it denied? I can understand the port but not icmp, can anyone explain that to me?
srue Fri, 09/21/2007 - 11:08
You probably need to ask Cisco about the reasoning behind this logic. maybe they saw no need to allow users to be able to use nat exemption based on ports/protocols
