Call Manger service won't start
Ginger Dillon Fri, 09/21/2007 - 16:14
Hi -
Hoping you broke your CCM RAID1 mirror set before installing ssh onto the server and were using BARS to back up CallManager? If you did, here is the BARS restore instructions -
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_installation_guide_chapter09186a00801ebeae.html
Note: If this just happened and you have a good mirror copy, you can try rebooting the server from this drive, which would not have the ssh software on it. And lastly, most important, I would call TAC on this. They may have another way to get your system back up and running, at least they'll give you the straight scoop and tell you whether or not you need to reinstall OS and CallManager.
Hope this helps! Ginger
