Mutlicast Configuration issue in LAN
Sep 21st, 2007
I need your valued advice on Multicast configuration in Cisco based local area network.
I had Cisco IP telephony and Cisco 6513 as in Core and Cisco 4503 in access. We have recently installed some novatec server based application. This application works on multicast group 225.1.1.42 and supported some features in Cisco IP phones.
I have configured my core and access switches for following configuration.
6513 Core switch
ip multicast-routing
interface vlan 501
ip pim sparse-dense mode
ip igmp-join group 225.1.1.42
4503 access switch :
The novatec server box is also in vlan 501. With this configuration it works for vlan 501. But when am configuring the same configuration for any other vlan suppose 502 as follows.
interface vlan 502
It doesn?t work for any other vlan then vlan 501. Whereas my inter vlan communication is proper.
Please suggest if I need other vlans to join this multicast group, do I need to configure something more then this?
Many thanks in advance for your appreciated assistance.
Jon Marshall Fri, 09/21/2007 - 13:01
Just a quick check. Do you know what ttl is being set on the multicast packets. You will need a ttl greater than 1.
Jon
shanus_id Sun, 09/23/2007 - 03:45
Thanks a lot jon. As you advised we changed the TTL value for multicast packets and the things are started working now.
Many thanks...
