SNMP on IPCC server
Sep 21st, 2007
A customer had an Security Audit performed and one of the action items is a Default SNMP Community string on the IPCC server. Can this service be disabled or will changing the string effect anything?
Joe
adignan Sat, 09/22/2007 - 05:40
SNMP should't be disabled, but you can change the string to something more secure. Make sure SNMP string is the same on all servers.
please rate helpful posts.
adignan - berbee
joeharb Sun, 09/23/2007 - 06:03
Thanks for the reply...can you explain what you mean by all servers...does this string have to match my callmanager and unity servers?
Joe
adignan Sun, 09/23/2007 - 13:29
No, just ipcc servers (routers, loggers, pg's, aw, hds, etc)
