WLC and DHCP
Hello All,
I have a WLC running 3.2.116.21. It is trunked with dot1q and the specific VLANs are allowed. I have defined an interface (call it Outside) for vlan 100 and assigned it an appropriate address. Also the defined DHCP server is a Cisco router acting as a gateway off of the wired LAN. Now, I've also defined a WLAN and tied it to the Outside interface. My problem is that when a wireless client successfully associates they get no IP address. The kicker is that when I do debug on the WLC I see the client's DHCP DISCOVER message go out. And then I see the router's DHCP OFFER message reply. However there is no DHCP ACK and the client never accepts the offered ip address. On another note, this works just fine for a DSL vlan that we've setup in exactly the same manner. DSL router is connected to an arbitrary VLAN and is acting DHCP server. The DSL VLAN is tied to a WLAN and clients can associate and recieve DHCP address no problem. I've rebooted the WLC and no affect, also I've tried disabling/enabling the DHCP proxy. No change in behaviour. I'm definitely all ears to any suggestions!!!!
TIA,
Andrew
Okay, found out what it was. Just not sure why. In no way related to DHCP issues. Noticed that when I statically assigned an address I still could not communicate. So, after some floundering I deselected static WEP as the security mechanism and used WPA with passcode. Voila! Worked like a champ...my new question then is this...why? The static wep key worked just fine for the DSL vlan instance but not for the Outside vlan.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
