WAAS inline deployment
Sep 21st, 2007
Hello All,
I'm deploying a couple of WAE-512's in "inline" mode for a customer. I have the configuration and seems pretty straight forward, looks like I just need to have the inlinegroup created and allow all VLAN's. I will also have a crossover connection from the gateway router to the WAE and straight through from the WAE to the core LAN infrastructure. Is there any other things I should look out for?, gotcha's,etc?. Just looking to see what other people experiences have been with this type of deployment. Thanks for your help!
krabe Sat, 09/22/2007 - 16:59
Beware of duplex issues that can pop-up from time to time on FE connections, hard coding can help avoid that. I would also suggest portfast where applicable ie switchports.
