Could not Access the FTP server from the outside interface (ASA 5510)
Sep 21st, 2007
Dear All,
I am setting up a test environment with the following configuration. Although I have created the ACL and also enable the Port re-direction, but I still not able to access the FTP server from the outside.
ASA Version 7.0(6)
hostname ACN-GW
domain-name anc.com
names
dns-guard
interface Ethernet0/0
nameif outside
security-level 0
ip address 172.16.10.1 255.255.255.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.100.1 255.255.255.0
interface Ethernet0/2
nameif Student
security-level 50
ip address 192.168.101.1 255.255.255.0
nameif management
security-level 0
ip address 192.168.200.1 255.255.255.0
management-only
ftp mode passive
access-list acl_inbound extended permit tcp any host 172.16.10,1 eq ftp
access-list acl_inbound extended permit tcp any host 172.16.10.1 eq ftp-data
tcp-map map
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (Student) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp 172.16.10.1 ftp 192.168.100.2 ftp netmask 255.255.255.255
static (inside,outside) tcp 172.16.10.1 ftp-data 192.168.100.2 ftp-data netmask 255.255.255.255
access-group acl_inbound in interface outside
route outside 0.0.0.0 0.0.0.0 172.16.10.2
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect ftp
service-policy global_policy global
: end
Kindly advise, did I miss out something from the configuration.
JC
froggy3132000 Sat, 09/22/2007 - 03:11
  • Bronze, 100 points or more
instead of
it should read
access-list acl_inbound extended permit tcp any any eq ftp
