BGP with 7204vxr npe-225
Edison Ortiz Sat, 09/22/2007 - 08:57
  • Hall of Fame,
    Founding Member
I highly suggest you become familiar with
Cisco Feature Navigator http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Choose the features you are looking for, match it with the hardware and be sure to read the caveats on that IOS release. If any of those caveats may affect the services you are running, try choosing an earlier or later version of such code.
Just by looking at your request, you are definitely in need for a k9 (security) feature set.
spremkumar Mon, 09/24/2007 - 01:56
  • Red, 2250 points or more
hi
Based on your inputs you may need to go either with advanced ip services version or advanced enterprise services feature set.
CFN link provided by Edison does it all for you to get the exact ios code.
regds
