E1 R2 digital Call SETUP Trobleshooting
Sep 22nd, 2007
Failure to make and recieve external calls
We noticed that a lot of ports remains at blocked at IN STATUS.
BAX-MTY#sh voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/0/0:1 17 r2-digital up up blocked idle y
0/0/0:1 18 r2-digital up up blocked idle y
0/0/0:1 19 r2-digital up up clearfwd idle y
0/0/0:1 20 r2-digital up dorm idle idle y
0/0/0:1 21 r2-digital up dorm idle idle y
0/0/0:1 22 r2-digital up dorm idle idle y
0/0/0:1 23 r2-digital up dorm idle idle y
0/0/0:1 24 r2-digital up dorm idle idle y
0/0/0:1 25 r2-digital up dorm idle idle y
0/0/0:1 26 r2-digital up dorm idle idle y
0/0/0:1 27 r2-digital up dorm idle idle y
0/0/0:1 28 r2-digital up dorm idle idle y
0/0/0:1 29 r2-digital up dorm idle idle y
0/0/0:1 30 r2-digital up up blocked idle y
0/0/0:1 31 r2-digital up up blocked idle y
I looked the following thread but I did't find something to change in my configuration.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Service%20Providers&topic=Voice%20over%20IP&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dde596b
Anyone knows what is the posible cause?
I attach the configuration and debug
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 09/24/2007 - 07:55
  • Hall of Fame,
    Founding Member
IOS version used ?
jcsromero Mon, 09/24/2007 - 08:18
!!! UPDATE !!!
There is an update related to this topic:
The problem was corrected on the Service Provider side ... they corrected some parameters inside their network Infrastructure.
This is the IOS Version:
Version 12.4(17)
flash:c2800nm-advipservicesk9-mz.124-17.bin
gogasca Mon, 09/24/2007 - 08:17
  • Green, 3000 points or more
Checking different customer configs and Telmex recommendation, and all points to this configuration: (Just change channels used)
controller E1 0/1
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
country telmex
category 2
answer-signal group-b 1
Please give it a try at the following config:
controller E1 1/0
framing NO-CRC4
clock source line
line-termination 75-ohm
ds0-group 0 timeslots 1-8 type r2-digital r2-compelled ani
cas-custom 0
country telmex
seizure-ack-time 30
category 2
dnis-digits min 4 max 4
dnis-complete
timer interdigit incoming 1000
groupa-callerid-end
voice-port 1/0:0
cptone mexico
Check the following:
For inbound calls from Telmex to router you can configure
dnis-digits min x max y
This will reduce the interdigit timer to 1 sec and we will collect between x and y digits from pbx for the dnis.
Have you already made a loopback test?
Let us know
jcsromero Mon, 09/24/2007 - 08:58
Thanks, I appreciate your advice ... I analyzed your configuration, It seems very useful and I will be using it next time.
I already posted an update about this topic and the problem was corrected on the Service Provider side. I appreciate your help!
