09-22-2007 01:30 PM - edited 03-11-2019 04:15 AM
I have a PIX 515 running 7.2(2). I am trying to set up a public and a private network to separate the traffic. My PIX doesn't seem to want to participate in the VLAN. VLAN 1 is my private VLAN and VLAN 2 is my public VLAN. My Switch is a 3560.
PIX Config
interface Ethernet1
no nameif
no security-level
no ip address
interface Ethernet1.1
vlan 1
nameif inside
security-level 100
ip address 10.0.0.1 255.255.255.0
interface Ethernet1.2
vlan 2
nameif public
security-level 10
ip address 172.16.0.1 255.255.255.0
Switch Config
interface FastEthernet0/1
switchport mode trunk
interface Vlan1
ip address 10.0.0.221 255.255.255.0
I can't ping either direction. I do see the MAC address for the PIX in the ARP cache on the switch.
What am I doing wrong?
09-22-2007 02:33 PM
Hi, where is the trunk config on the PIX can you post that portion.
Rgds
Jorge
09-22-2007 02:36 PM
What Trunk configuration for the PIX? Maybe that is what I am missing.
09-22-2007 02:45 PM
[EDIT] never mind and sorry about that, 802.1q is automatically enable when creating logical interfaces.
Is the interface up on the PIX where you have the trunk.
If you connect a host in one of the vlans and try to ping its defaul gateway say 10.0.0.1 can you get replies.
Rgds
Jorge
09-23-2007 08:40 AM
Mark, few things to look into.
First: From the PIX if you can ping the interfaces 172.16.0.1 and 10.0.0.1 that will
indicate they are pingable.
Second: From the switch issues " show interface trunk " to see the vlans passing through that trunk.
Third: Make sure you have created the vlans in the switch correspnding to these two new routable networks , check your vlan database.
Forth: Assign proper vlan membership on ports corresponding to these two new vlans.
Fith: From lower security level to highest security level you need access list to allow communications from 172.16.0.0/24 to 10.0.0.0/24 network, that include icmp or any other ports required.
Jorge
