3005 event log error
Sep 22nd, 2007
Hello to all,
My 3002 client successfully passes the IKE phase 1, but I get the following error. The client is listed as a GROUP and not a USER
17404 09/22/2007 20:22:19.180 SEV=3 AUTH/80 RPT=22134
A user attempted to log on using only group credentials: handle = 258, user =
Thanx in advance
ajagadee Sat, 09/22/2007 - 21:44
The problem is that you have a username that is the same as the group name. The
Concentrator requires that all group/user names are unique even if you have an external
authentication server.
By using a different username you should not see this error.
I hope it helps.
kitprice1 Sun, 09/23/2007 - 18:10
It is a different user name. There is only one connection to the concentrator, and it is me, and I am using PPTP. This user that is failing is a HW client which is a GROUP, using a group name and user name that are different than me. When I set
"authentication" to none, the HW client connects.
I am using INTERNAL authentication. PPTP users do not have a problem, I think this is an IPSec issue of some kind.
