ASA 8.0 (EZVPN Server) router2821 (EZVPN remote) , Not working
Sep 22nd, 2007
I am configurin my ASA as an EZVPN server. This is the configuration:
tunnel-group Redes type remote-access
tunnel-group Redes general-attributes
address-pool RedesPool
default-group-policy Redes
tunnel-group Redes ipsec-attributes
pre-shared-key *
tunnel-group VPNROUTERS type remote-access
tunnel-group VPNROUTERS general-attributes
default-group-policy VPNROUTERS
tunnel-group VPNROUTERS ipsec-attributes
pre-shared-key *
isakmp ikev1-user-authentication none
group-policy VPNROUTERS internal
group-policy VPNROUTERS attributes
vpn-tunnel-protocol IPSec
secure-unit-authentication disable
nem enable
address-pools none
ipv6-address-pools none
group-policy Redes internal
group-policy Redes attributes
dns-server value 10.1.4.2 10.1.4.3
password-storage disable
default-domain value mf.gov.ve
I am configurin a router as EZVPN client. This is the configuration:
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto ipsec client ezvpn VPNROUTERS
connect manual
group VPNROUTERS key router1
mode network-extension
peer 200.11.187.58
acl 101
xauth userid mode interactive
The VPN negotiation gets stuck at this level:
*Sep 20 19:59:46.119: ISAKMP:(0:255:SW:1):Need config/address
*Sep 20 19:59:46.19: ISAKMP:(0:255:SW:1):Input = IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE
*Sep 20 19:59:46.119: ISAKMP:(0:255:SW:1):Old State = IKE_P1_COMPLETE New State = IKE_CONFIG_MODE_REQ_SENT
*Sep 20 19:59:46.123: ISAKMP (0:134217983): received packet from 200.11.187.58 dport 500 sport 500 Global (I) CONF_ADDR
*Sep 20 19:59:46.123: ISAKMP: set new node -1061602860 to CONF_ADDR
%SYS-3-CPUHOG: Task is running for (6004)msecs, more than (2000)msecs (0/0),process = Crypto IKMP.
-Traceback= 0x40275E38 0x41245068 0x4124876C 0x41248884 0x427BAA00 0x427BD900 0x427BB2C4 0x427BBC48 0x427BC5F0 0x427B5354 0x427D5A84 0x42C9EDD0 0x427D801C 0x427A9244 0x427AAC2C 1
*Sep 20 19:59:46.119: ISAKMP:(0:255:SW:1):Old State = IKE_I_AM1 New State = IKE_P1_COMPLETE
Since i am configuring network extension, i am not suppouse to get conf_addr state.
I do not know why i am getting this state.
didyap Thu, 09/27/2007 - 14:46
  • Silver, 250 points or more
Add the following lines to your group-policy VPNROUTERS attributes
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
ipsec-udp enable
ipsec-udp-port 10000
split-tunnel-policy tunnelall
split-tunnel-network-list none
default-domain none
Following link may help you
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080809222.shtml
andrew-usankin Fri, 07/31/2009 - 12:57
Try this:
Just beat my head on this one last night and finally this morning I found out that since it's a client (even though hardware client) you need to give it IP address.
