Downgrading IOS
Answered Question
Sep 23rd, 2007
I am trying to downgrade a device, but when I do copy tftp flash, it does ask me if I want to erase the current ios, instead,I get the following error.
copy tftp flash
Address or name of remote host [X.X.X.X]?
Source filename [c3845-advipservicesk9-mz.124-11.T1.bin]?
Destination filename [c3845-advipservicesk9-mz.124-11.T1.bin]?
Accessing tftp://X.X.X.X/c3845-advipservicesk9-mz.124-11.T1.bin...
Loading c3845-advipservicesk9-mz.124-11.T1.bin from X.X.X.X (via GigabitEthernet0/1): !
%Error copying tftp://10.250.7.250/c3845-advipservicesk9-mz.124-11.T1.bin (Not enough space on device)
XXB#
The TFTP server is another 3845 I have configured as a tftp server to download the IOS from. I also want to specifically delete the current flash file, but I get the following error:
XXB#erase flash: c3845-advipservicesk9-mz.124-15.T1.bin
% Invalid input detected at '^' marker.
Correct Answer by Richard Burts about 9 years 10 months ago
Mayamba
I do not have a lot of experience with the 3845 but I believe that you want to use the command delete flash:c3845-advipservicesk9-mz.124-15.T1.bin instead of the command erase flash:c3845-advipservicesk9-mz.124-15.T1.bin. Give it a try with the different command and let us know what happens.
Rick
Overall Rating: 5 (2 ratings)
markraves Sun, 09/23/2007 - 01:53
I'm a bit new at this.
I had a similar problem on my 4500 switch, when upgrading. What I had to do was just to use the command squeeze.
When you erase something from the filesystem, it's not gone until you squeeze it. At Least not on my switch:)After it's squeezed away, try downloading it again.
However, when it's squeezed, it's NO LONGER THERE!
Joseph W. Doherty Sun, 09/23/2007 - 03:54
Some of the newer routers, such as the 3800 series I believe, support different filesystems on some flash.
See http://www.cisco.com/en/US/products/hw/routers/ps259/products_configuration_guide_chapter09186a008007e5fb.html
What might not be clear is you can often switch the filesystem mode during the clearing of the flash. Use erase for the one mode or format for the other.
Also some older filesystems, those that are setup with erase, don't all support squeeze.
PS:
Just found another paper on the different filesystems, see: http://www.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a00800a7515.shtml
NB: In the last link, the information about commands usage for the "C" filesystem, I believe to be incorrect.
Correct Answer
Richard Burts Sun, 09/23/2007 - 07:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mayamba
Rick
Richard Burts Sun, 09/23/2007 - 08:09
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Mayamba
Thank you for using the rating system to indicate that your problem is resolved (and thanks for the rating). It makes the forum more useful when people can read about a problem and can know that they will read a solution to that problem. I encourage you to continue your participation in the forum.
Rick
