Redundant VPN Entry
Sep 23rd, 2007
Hello Everybody
I have a cisco 18xx router connecting to PIX (6.3). There are about 10 sites which connects to PIX on site A. What we need is if a link between any router and SiteA goes down it should dial the VPN link to the siteB with same PIX and other setup.
Basically we are looking for redundant VPN configuration on cisco router.
Please help
Camila..
Overall Rating: 4 (1 ratings)
tstanik Fri, 09/28/2007 - 10:39
  • Bronze, 100 points or more
For redundant VPN configuration you can create a policy on your routers so that when the primary link goes down it will use the backup. Also configure the router which is dialled to forward the traffic to the PIX. Following link may help you
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008052d450.shtml
