Intervlan Routing with NAT
Sep 23rd, 2007
Hi have 7206 with 2 fa port. Port 1 and is connected to my ISP router. While port 2 is connected to a layer 2 switch going to my LAN. I configured my switch with dot1q trunking and 7206 router's fa4/0 with dot1q encapsulation. Trunking is working fine.
But my objective is to run a NAT static and dynamic, but what happens is that no translations are being made. I believe that the router should be able to reach other vlans. But i cannot think why the translation is not working. Can you feed me some answers? Thanks in advance.
Below are my config on 7206 router
interface FastEthernet4/0.1
encapsulation dot1Q 1 native
ip address 203.x.x.129
ip nat outside
interface FastEthernet4/0.2
encapsulation dot1Q 2
ip address
ip nat inside
ip nat inside source list 10 interface FastEthernet4/0.1 overload
access-list 10 permit
JORGE RODRIGUEZ Sun, 09/23/2007 - 09:56
Hi Rick, try doing it as:
ip nat pool mypool netmask
ip nat inside source list 10 pool mypool overload
access-list 10 permit log
[edit] if you want to do static nat between the inside and outside use the " ip nat inside source static 192.168.11.x 203.82.38.y where "x" is the specific inside host and "y" is the allocated external address for the static nat translation.
Edison Ortiz Sun, 09/23/2007 - 10:06
Per your config, it seems both the ISP and the Layer2 switch are connected to your router on the same physical interface (Port F4/0).
This is an odd configuration where you are tagging packets for translation as the come in and as they exit on the same physical interface.
JORGE RODRIGUEZ Sun, 09/23/2007 - 10:13
Edison but I think theorically the translation shoudl occor, the subinterfaces have the nat inside/outside option, I don't tink it nessesarily need to have a dedicated phycial interface for the inside/outside I could be wrong then.
worldcalltel Sun, 09/23/2007 - 23:40
I did all you suggested but I'm still getting the same results. Any ideas on what is going on?
worldcalltel Mon, 09/24/2007 - 01:52
I added up the route-map command. Unfortunately, it was still failing. I do try to use the debug ip nat, and nothing happen, as if the translation is not really not working, but the layer 1 connection of each devices are working well.
route-map primary-nat permit 10
match ip address NAT 10
set ip next-hop 206.x.x.14
Edison Ortiz Mon, 09/24/2007 - 03:53
How the layer1 connection is made when both devices are going to the same physical port ?
Can you post the show ip nat translation and show ip nat stat output ?
JORGE RODRIGUEZ Mon, 09/24/2007 - 12:10
Rick, this is a totaly new issue from your original post with just NATing which was proved by EdisonOrtiz to work, you did not throw PBR in this equation . What router advertizes the 206.x.x.14, is 206.x.x.14 another interface on the SP router ? please post the whole 7206 router config and indicate what role does 206.x.x.14 have.
ohassairi Mon, 09/24/2007 - 03:30
i think the interface connected to your ISP (what you called port1) should be ip nat outside.
can you paste your default route?
