VLAN database or configure terminal
Sep 23rd, 2007
On the CCNA exam does it matter if you configure VLANs and VTP by typeing 'vlan database' and configuring everything that way or by typing 'configure terminal' and configuring it that way? Thanks.
Overall Rating: 4 (1 ratings)
Kevin Dorrell Sun, 09/23/2007 - 08:45
It doesn't make any difference which way you do it, although it is possible the simulator will only allow you one way, so you should know both. But you should also know that "vlan database" is deprecated and will be dropped from IOS at some time in the future.
Kevin Dorrell
