Is the '?' allowed during simulations?
Sep 23rd, 2007
When in a simulation is the questionmark available to see a list of available commands or the tab key? Thanks.
dlillis65 Sun, 09/23/2007 - 10:26
No. No Tab or ? keys allowed. The up arrow key is allowed though
rileymartin Sun, 09/23/2007 - 10:32
If I type the command incorrectly will the router reply as usual and tell me or will I just get another prompt and mabey not know if what I typed is a valid command or not? For that matter, does it count against you if you type a command incorrectly once or twice but then type the command correctly?
Phillip Hichens Wed, 10/10/2007 - 02:40
It is an simulation, and they are simulating the real thing.
For all of the exams of late, that I've written (CCNA and a number of 642-s) you can use TAB and ?.
Though TAB and ? does not always work like the real thing, being a simulation.
Check your configs with "sh run" and other sh commands to make sure you achieved the goals for the simulation.
Remember to always do a "copy run start" at the end of your simulation.
Phillip
