is there a "conversion tool" to convert 6.3 config to 7.0 config on Pix
Sep 23rd, 2007
i have up dated my backup pix from 6.3 to 7.0, there were a few error messages from the config.
is there a tool availble that you can input the 6.3 config and it produces the 7.0 config, so we can correct any possible errors before the live conversion?
Jagdeep Gambhir Sun, 09/23/2007 - 19:21
There's no tool to convert PIX 6.x to ASA 7.x configuration. When a Pix is upgraded from 6.x to 7.x SW automatically does that for you, looking at "show start error" output after upgrade will tell if there are any commands which are not converted.
