Late collisions vs. Local collisions
Sep 23rd, 2007
Does anyone have any links to information that will identify which of these are late collisions and which are local collisions? I can't find it in either the ICND Intro or ICND books.
caused by excessive media latency
considered abnormal network operation
occurs after the first 64 bytes of a frame are transmitted
damaged frame retransmitted
occasionally occurs in normal network operation
jam signal sent to intentionally ocrrupt frame
scottmac Sun, 09/23/2007 - 19:50
Oiiginal Ethernet was designed so that even with the minimum frame size (64bytes / 512 bit times), if a (normal) collision occurred, anywhere on the (maximum length) wire, it would be sensed.
That's the key to figuring out "normal / local" versus "Late."
So, the first three, as you have them listed, are "Late"; the last two are "normal / local" ... the damaged frame retransmitted is a little ambiguous, but at strictly at the layer two level, I"m pretty sure they would consider it "normal."
The "JAM" signal is sent once a collision is detected in the first 64 bytes to ensure that all hosts heard the collision.
Good Luck
Scott
