CISCO 3640 ???
Sep 23rd, 2007
Hello technical expert,
I have Cisco 3640 router that have 16MB flash memory and 48MB DRAM memory. I want to install a NM-ESW-16 16 ports network module in my router. I used Software Advisor of CISCO web site and that told me minimum Software Image c3640-i-mz.123-23, Minimum DRAM 50, Minimum Flash6 16. My router?s DRAM is smeller than requirement. But I copied 12.3-23 IOS and my router boots it without any problems. But there is not my 16 ports nm in show run command result.
Why I can?t see my 16 ports? Is it from DRAM ?
spremkumar Sun, 09/23/2007 - 19:48
  • Red, 2250 points or more
Can you post the output show version here ?
regds
Kevin Dorrell Mon, 09/24/2007 - 01:53
  • Green, 3000 points or more
When you interrogated the Software Advisor, did you tell it that you had an ENM-SW-16 in the chassis? I am kind of surprised that the -i- image supports it, but I may be wrong there. It would be well to double-check though.
Kevin Dorrell
Luxembourg
michaelchoo Tue, 09/25/2007 - 17:36
According to the EtherSwitch module data sheet, the minimum IOS level for 3620 and 3640 was 12.2(8)T, so your IOS *should* be fine.
This may sound like a stupid question, but since it happened to me before.... Are you sure that the NM is plugged in properly to the NM slot?
